5 Axis Grinding Corner Radius End Mill, 3/4"" Milling Dia., Number of Flutes: 4, 1-5/8"" Length of Cut, TiAlN Model: 40750R
main picture
We compared price of 5 Axis Grinding Corner Radius End Mill, 3/4"" Milling Dia., Number of Flutes: 4, 1-5/8"" Length of Cut, TiAlN Model: 40750R across hundreds of online stores. We found 5 Axis Grinding Corner Radius End Mill, 3/4"" Milling Dia., Number of Flutes: 4, 1-5/8"" Length of Cut, TiAlN Model: 40750R in 1 store with lowest price $166.00 in Grainger. For detailed price comparison of 5 Axis Grinding Corner Radius End Mill, 3/4"" Milling Dia., Number of Flutes: 4, 1-5/8"" Length of Cut, TiAlN Model: 40750R check table below.
Merchant Price -
Grainger [show price]
5 Axis Grinding Corner Radius End Mill, 3/4"" Milling Dia., Number of Flutes: 4, 1-5/8"" Length of Cut, TiAlN Model: 40750R description from Grainger
Carbide End Mill, Grade Micrograin Carbide, Corner Radius End Mill Style, Dimension Type Fractional Inch, Milling Dia. 3/4 In., Number of Flutes 4, Length of Cut 1-5/8 In., Center Cut Cutting Type, Overall Length 4 In., Finish TiALN Coated, Shank Dia. 3/4 In., Single End, Cutting Direction Right Hand, Helix Angle 35 Degrees /38 Degrees , Corner Radius 0.030 In., End Mill Application Finishing
Customer review
I am so happy I bought end mills. They fit well, look really expensive and will look great with anything. The 5 Axis Grinding end mills are well-made ...
