ABS Battery, Voltage 12, Battery Capacity 38Ah, Threaded Receptacle Terminal Type Model: 5EFH3
We compared price of ABS Battery, Voltage 12, Battery Capacity 38Ah, Threaded Receptacle Terminal Type Model: 5EFH3 across hundreds of online stores. We found ABS Battery, Voltage 12, Battery Capacity 38Ah, Threaded Receptacle Terminal Type Model: 5EFH3 in 1 store with lowest price $295.00 in Grainger. For detailed price comparison of ABS Battery, Voltage 12, Battery Capacity 38Ah, Threaded Receptacle Terminal Type Model: 5EFH3 check table below.
Merchant | Price | - |
Grainger | [show price] |
ABS Battery, Voltage 12, Battery Capacity 38Ah, Threaded Receptacle Terminal Type Model: 5EFH3 description from Grainger
Battery, Battery Chemistry Sealed Lead Acid, Voltage 12, Battery Capacity 38Ah, Housing Material ABS, Terminal Type Threaded Receptacle, Terminal Connection M6, Height 6-7/8 In., Width 6-9/16 In., Depth 7-11/16 In., Black, Rechargeable Up To 5 Years, For Use With All Purpose
Customer review
I always wanted any product from Grainger Approved, but now I see, that it's not what I was hoping!
