Aro 1/4"" 24VDC 3-Way, 2-Position Solenoid Air Control Valve Model: CAT66P-024-L
main picture
We compared price of Aro 1/4"" 24VDC 3-Way, 2-Position Solenoid Air Control Valve Model: CAT66P-024-L across hundreds of online stores. We found Aro 1/4"" 24VDC 3-Way, 2-Position Solenoid Air Control Valve Model: CAT66P-024-L in 1 store with lowest price $112.30 in Grainger. For detailed price comparison of Aro 1/4"" 24VDC 3-Way, 2-Position Solenoid Air Control Valve Model: CAT66P-024-L check table below.
Merchant Price -
Grainger [show price]
Aro 1/4"" 24VDC 3-Way, 2-Position Solenoid Air Control Valve Model: CAT66P-024-L description from Grainger
Solenoid Air Control Valve, 3-Way, 2-Position, Normally Closed, Actuator/Return Solenoid/Spring, Body Style Body Ported, Pipe Size 1/4 In., Voltage 24VDC, 2.2 CFM, Coefficient of Volume 0.062, DIN Connectors Electrical Connections, Shifting Technology Direct, Power Consumption 5 W, Pressure Range 0 to 150 psi, Ambient Temp. Range 0 Degrees to 122 Degrees F, Overall Height 3-9/16 In., Overall Length 2-5/32 In., Overall Width 1-1/4 In., NEMA Classification NEMA 4
Customer review
Aro has usually good products, and this enclosures & cases called Aro 1/4"" 24VDC 3-Way, 2-Position Solenoid Air Control Valve Model: CAT66P-024-L is not an exception. It's one of best product around this price.
