Aro 1/8"" Manual Air Control Valve with 3-Way, 2-Position Air Valve Type Model: 202-C
main picture
We compared price of Aro 1/8"" Manual Air Control Valve with 3-Way, 2-Position Air Valve Type Model: 202-C across hundreds of online stores. We found Aro 1/8"" Manual Air Control Valve with 3-Way, 2-Position Air Valve Type Model: 202-C in 1 store with lowest price $43.95 in Grainger. For detailed price comparison of Aro 1/8"" Manual Air Control Valve with 3-Way, 2-Position Air Valve Type Model: 202-C check table below.
Merchant Price -
Grainger [show price]
Aro 1/8"" Manual Air Control Valve with 3-Way, 2-Position Air Valve Type Model: 202-C description from Grainger
Manual Air Control Valve, 3-Way, 2-Position, Pipe Size 1/8 In., Actuator/Return Roller Lever/Spring, Coefficient of Volume 0.2, 7.5 CFM, Temp. Range 32 Degrees to 160 Degrees F, Max. Pressure 150 psi, Connection NPT, Normally Open / Normally Closed Normally Closed, Body Material Zinc Die Cast, Overall Length 1-3/4 In., Overall Height 1-5/8 In., Overall Width 11/16 In.
Customer review
This is awful, even for 43.95. I made a terrible mistake with this one. Even if Aro is known for quality products I am thinking about selling mine Aro 1/8"" Manual Air Control Valve with 3-Way, 2-Position Air Valve Type Model: 202-C.
