Century 7/8 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,200-230/460 Voltage,Frame 48 Model: FC1086AF
We compared price of Century 7/8 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,200-230/460 Voltage,Frame 48 Model: FC1086AF across hundreds of online stores. We found Century 7/8 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,200-230/460 Voltage,Frame 48 Model: FC1086AF in 1 store with lowest price $417.75 in Grainger. For detailed price comparison of Century 7/8 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,200-230/460 Voltage,Frame 48 Model: FC1086AF check table below.
Merchant | Price | - |
Grainger | [show price] |
Century 7/8 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,200-230/460 Voltage,Frame 48 Model: FC1086AF description from Grainger
Condenser Fan Motor, Motor Design Permanent Split Capacitor, Motor Enclosure Design Open Air-Over, 7/8 HP, RPM Range 1001-1100, Nameplate RPM 1075, Voltage 200-230/460, 48Y Frame, No. of Speeds 1, Overall Length 14-1/4 In., Shaft Length 4-3/16 In., Motor Mounting Position Vertical Shaft Up, Features Energy Efficient, Auto Protector, High Thrust Capacity, Reversible, Motor Shaft Rotation CW/CCW, Full Load Amps 4.6/2.3, Band Motor Mounting Type, Motor Thermal Protection Auto, Ins. Class F
Customer review
For 417.75, it is very cheap product. If i'll need another condensers, i'll definitely buy this again!
