Optimum 3 Motor HP Floor Drill Press, 230 Model: B34H
We compared price of Optimum 3 Motor HP Floor Drill Press, 230 Model: B34H across hundreds of online stores. We found Optimum 3 Motor HP Floor Drill Press, 230 Model: B34H in 1 store with lowest price $3078.00 in Grainger. For detailed price comparison of Optimum 3 Motor HP Floor Drill Press, 230 Model: B34H check table below.
Merchant | Price | - |
Grainger | [show price] |
Optimum 3 Motor HP Floor Drill Press, 230 Model: B34H description from Grainger
Floor Drill Press, Drive Type Belt, Swing 22 In., Voltage 230, Motor HP 3, Chuck Size 5/8 In., Number of Speeds 9, Spindle Speed 175 to 5700, Capacity Steel 1 In., Capacity Cast Iron 1-1/2 In., Spindle Taper 4MT, Spindle Travel 6-1/4 In., Base Size 15-11/32 In. x 14-9/16 In., Table Work Surface 19-1/2 In. x 15-3/4 In., Amps AC 6, Hz 60, Phase 3, Includes Chuck and Arbor, Safety Drill Guard, Halogen Work Light, Tool Ejector, Table Slot Size 1/2 In., Column Dia. 4-1/2 In.
Customer review
Optimum 3 Motor HP Floor Drill Press, 230 Model: B34H is my most favourite twist drill bits! Price of 3078.00 is also great :) I <3 this shop!
