Weg 10 HP Saw Arbor Motor,3-Phase,1720 Nameplate RPM,208-230/460 Voltage,Frame 90L Model: 01018ES3ESA90LR
We compared price of Weg 10 HP Saw Arbor Motor,3-Phase,1720 Nameplate RPM,208-230/460 Voltage,Frame 90L Model: 01018ES3ESA90LR across hundreds of online stores. We found Weg 10 HP Saw Arbor Motor,3-Phase,1720 Nameplate RPM,208-230/460 Voltage,Frame 90L Model: 01018ES3ESA90LR in 1 store with lowest price $1986.00 in Grainger. For detailed price comparison of Weg 10 HP Saw Arbor Motor,3-Phase,1720 Nameplate RPM,208-230/460 Voltage,Frame 90L Model: 01018ES3ESA90LR check table below.
Merchant | Price | - |
Grainger | [show price] |
Weg 10 HP Saw Arbor Motor,3-Phase,1720 Nameplate RPM,208-230/460 Voltage,Frame 90L Model: 01018ES3ESA90LR description from Grainger
Saw Arbor Motor, 3-Phase, 10 HP, 1720 Nameplate RPM, 90L Frame, Voltage 208-230/460, 60 Hz, 3 Phase, 31.2-28.2/14.1 Full Load Amps, Motor Mounting Type Rigid Base, Motor Thermal Protection None, Ins. Class F, 1.00 Motor Service Factor, Motor Bearings Ball, Ambient Temperature 40 Degrees C, CCWSE Motor Shaft Rotation, Length Less Shaft 25-1/4 In., Shaft Dia. 30mm, Shaft Length 2-1/2 In., Standards UL Recognized (E104590) , CSA Certified (LR50.962-9/13/14) , CE, Includes PG Threaded Terminal Box
Customer review
I red all reviews for automotive, but Weg 10 HP Saw Arbor Motor,3-Phase,1720 Nameplate RPM,208-230/460 Voltage,Frame 90L Model: 01018ES3ESA90LR seems to be right action
